Q&A - Gatehouse
Kickstarter 4 developments here! This is a read-only forum.
Re: Q&A - Gatehouse
Post by JenneyOC » Wed Mar 09, 2016 1:12 am
LIVE STREAM QUESTIONS: 03/08/16
1. What can you swap out your draw bridge for?
A- those would be beans.
Re: Q&A - Gatehouse
Post by JenneyOC » Mon Mar 07, 2016 9:33 pm
Update 03-07-16
1. Is the gatehouse floor a huge trapdoor?
A- Yes. And it's a cool one.
2. Do the double doors of the Gatehouse open and close? Can they be removed like the smaller doors from the other Kickstarters?
A- The gatehouse double doors are hinged. They will most likely not be easily swappable. The drawbridge will also be hinged on an axle. That will be easily swappable for alternate sculpts.
3. Is every piece made of Dwarvenite-G in KS4? I mean, even the mountain cliffs, the add-ons for previous Kickstarters, etc... or just the larger Castle pieces?A- No. Most standard sized pieces will be regular dwarvenite. Stuff like the cliffs, accessories, crenellations, etc. Big items will be made of Dwarvenite G. All the castle walls, the big 8x8 floors, the wall spacers, etc
4. Also, any videos that show the drawbridge in action? Does it rise and lower with some sort of chain action (like a real drawbridge might), or is it just hinged at the base, and you raise and lower it yourself?
A- We'll have some drawbridge stuff to show soon.
Q&A - Gatehouse
Post by JenneyOC » Sun Mar 06, 2016 6:28 pm
LiveStream Launch Q+A - 03/06/16
1. Are the double door arch walls double sided?
A- Yes it is double sided.
2. Will it fit between two 2x2 dungeon tiles?
A- Yes both arch walls have a 2x4 footprint, so 2 dungeon tile will fit underneath.
3. Any chance of a broken bridge?
A- That is an interesting idea.
Return to “Codex Valoria”
