Q&A - Dwarvenite-G
Kickstarter 4 developments here! This is a read-only forum.
Re: Q&A - Dwarvenite-G
Post by JenneyOC » Mon Mar 07, 2016 9:34 pm
Update 03-07-16
1. Is there an obvious tactile difference (feel) between the original Dwarvenite stuff and the new Dwarvenite-G stuff?
A- Dwarvenite G with be more rigid than standard Dwarvenite. It will also be slightly lighter. In hard it will feel very similar to the standard Dwarvenite.
Q&A - Dwarvenite-G
Post by JenneyOC » Sun Mar 06, 2016 6:33 pm
LiveStream Launch Q+A - 03/06/16
1. Can you talk about the G in Dwarvenite-g?
A- It is infused with Gorgon breath making it stronger and able to make larger sized pieces than Dwarvenite.
3. Is Dwarvenite-g more brittle?
A- Yes, it is stronger and stiffer than Dwarvenite, which means it is also technically a bit more brittle than Dwarvenite.
4. Will Dwarvenite-g survive a fall from a table?
A- Absolutely.
5. Is Dwarvenite-g less prone to warping?
A- Yes, this is one of the reasons why this material is so much better for large pieces.
Return to “Codex Valoria”
