Q&A - Castle Floors
Kickstarter 4 developments here! This is a read-only forum.
Q&A - Castle Floors
Post by JenneyOC » Sun Mar 06, 2016 6:41 pm
LiveStream Launch Q+A - 03/06/16
1. Are those massive flat floor pieces?
A- Why yes, yes they are.
2. Will there be Marble floors?
A- No
3. 4x4 or 8x8 floor packs?
A- Its possible.
4. Is the 8x8 floor double sided. Or will the bottom be smooth with just the holes.
A- No the 8x8 floor is not double sided, and the bottles will look like the bottoms of other DF pieces.
Re: Q&A - Castle Floors
Post by JenneyOC » Mon Mar 07, 2016 9:38 pm
Update 03-07-16
1. Can we see a 4” floor surrounded by 1” extensions.
A- We have a full tower hands on video forthcoming. Still need to generate enough fully functional prototypes.
2. Will the 8x8 flagstone floors have CBS holes?
A- The 8x8 flagstone floor (and 4x4 flagstone floor) have CBS holes on the underside. By inserting CBS corner posts under hem this allows the floors to work as risers, exactly 2" high. So they can double as both floors and elevation platforms. If you also use double corner posts you can insert CBS walls under the floor too to make it appear solid.
3. ...a little outside the box - but could the 8x8's get post holes and be used with City Builder? Would make great Base for buildings....
A- The CBS holes are on the bottom (see above).
4. What is the single 1x1 floor tile for in the Citadels?
A- If you are not interested in backing your walls (for ease of play/budget/etc.) then there is a gap in the floor-plan which the 1x6s, the 1x2s, and 1x1 fill.
Post by JenneyOC » Wed Mar 09, 2016 12:37 am
Questions 03/07/16
1. And where do the floor extensions fit in (and why is there an odd number of them)?
A- Floor extension fit around the 4" diameter floor making it a 6" diameter floor... Some of your floors are 3/4 floors not full floors. the number of extensions allows you to fill all available sides.
Post by JenneyOC » Wed Mar 09, 2016 1:17 am
LIVE STREAM QUESTIONS: 03/08/16
1. What is the true size of the 8x8?
A- The 8"x8" floor is set to be precisely 203.2mm x 203.2mm
2. will there be 8x8 floor packs?
A- Absolutely.
Return to “Codex Valoria”
