Double Thick Wall Corner platforms?
Re: Double Thick Wall Corner platforms?
Post by geekjeff » Fri Apr 01, 2016 9:23 am
Alternately, you can go the route the Royal Stronghold does on its back wall - use 4x4 or 4x8 Roof Platforms instead of Corner Wall/Corner Transistion Platforms. Fill in that spot with a 2x2 dungeon or trapdoor tile.
Post by Talistran » Thu Mar 31, 2016 10:17 pm
But that leaves a difference in platform height no matter what...
No kosher IMO.
Post by biowizard » Thu Mar 31, 2016 2:51 pm
You could also use a spacer cube but that option would occupy the inner wall space.
Post by geekjeff » Thu Mar 31, 2016 11:45 am
I think it was you I replied to on the Kickstarter comments, but in case not: Per Nate & Elye, stairs go there.
If you don't dig that look, you could use a 4x4 flat roof platform from the addon pack in place of that Corner Transistion Platform and then stick any 2x2 in that spot. That's how the Royal Stronghold back wall is made actually.
Post by Talistran » Thu Mar 31, 2016 11:35 am
On Double Thick Wall Corners, what goes on top of the inside corner post as far as Platforms go?
It seems to be a major piece missing, a 2x2" platform that will make the corner the same height for crenellations to be added. And then, what crenellation goes there?
Return to “Kickstarter 4”
