KS5 - Magnets in bases
Re: KS5 - Magnets in bases
Post by kitenerd » Thu Oct 11, 2018 11:47 am
OK - a bit more info - we are all learning as we go
the 2mm magnets i used were N35
the 1mm were N38
so i could get stronger ones... hmmm...
I will look into that (especially for the freestanding walls which i would be cool if they could grip through a tile, but i doubt it) - but the force of these magnets was enough for most pieces (the beefiest cavern walls would benefit from 2 magnets or a stronger magnet)
stronger would make a greater challenge for the glue... which is my weak link at this point
Post by Vegomatic » Thu Oct 11, 2018 2:10 am
Seraphis the Bland got some info from Chuck and had posted in another thread a while back:
"You want N50 or N52 magnets. The "N" just stands for "neo" or neodymium. The number is what indicates strength and 52 is the strongest for neodymiums. You'll want that because the magnets we use are pretty small. Despite being the "strongest", N52's are actually pretty cheap. Ebay is a great source for them. Just pay attention to the size. The largest we use for wall accessories are discs 3mm thick and 5mm across."
Seems like there were some questions regarding magnets that were addressed in by the Knightess during the KS. I don't see them right now, but remember reading them somewhere...
Post by kitenerd » Thu Oct 11, 2018 1:20 am
Update - i showed these to my son and he was stoked he pulled up a tile to check out the magnet and the magnet stayed behind (i had been sliding them off) - two more failed while he was handling them
so Gorilla Glue is a FAIL!
I will experiment with other adhesives
Post by kitenerd » Wed Oct 10, 2018 6:23 pm
yeah - that occured to me - i was just adding magnets to the scene i need to rebuild for friday (i had it on a piece of MDF covered with a piece of cloth, but the cat decided to lay on it and so it is totally destroyed!) and it had a couple of free standing walls
not sure they will have the strength to pull through another tile (pretty sure they won't) but it would be worth doing to use them directly on the trays
Post by GardenDM » Wed Oct 10, 2018 6:20 pm
Wed Oct 10, 2018 5:10 pm
no idea relative strength
mine are definitely wider (ease of handling) i will need to get tiny ones for freestanding walls as the bases aren't big enough
not sure what thickness DF is using
Don't the FSW usually go on top of dungeon pieces? Or do you use them directly on the terrain tray?
Post by kitenerd » Wed Oct 10, 2018 5:10 pm
Post by Harneloot » Wed Oct 10, 2018 4:53 pm
I am so glad I switched my DoD order at the last minute to Magnets as I had wavered strongly until the very end! :D
Any idea how strong the the magnets you used are compared to the stock DF factory magnets?
Post by GardenDM » Wed Oct 10, 2018 3:34 pm
@kitenerd - Thank you for the update and the demo.
I have magnetized DoD pieces that I've played with and those completely sold me on magnets. I'll probably go back and magnetize some old stuff. Sewers seems like a great place to start since they're kind of fiddly with the separate walls, floors, and channels to juggle. The early (non double-sided) chasm ledges from KS2 would also benefit from this.
Post by Kryzsko » Wed Oct 10, 2018 3:16 pm
Wed Oct 10, 2018 1:37 pm
OK - I am officially a convert!
Just magnetized a trial set of caverns and sewers (which have lots of bits and really benefit from sticking together) and i am going to order a ton of more magnets and magnetize EVERYTHING
terrible picture, but this is a terrain tray held VERTICALLY with my sewers and caverns bits on it
game changer for me who lacks the area to leave anything set up
I used 10mm x 2mm ZD2 and 7/16" x 1/32" ZD701 from K&J magnetics
ZD2 = 25 for 8.50 (surplus)
ZD701 = 20cents each
I also have a sample coming from eBay that were half that price - which considering how many hundreds i need might be worth waiting extra time for
my experience - there is a LOT of variation in the recesses on the bottom of the pieces - it doesn't matter - the magnets do not need to be flush, the field is strong enough that they hold
i put them on with a glop of glue the size of a pea (gorilla contruction adhesive) and pushed them until they sank in - made sure they were flatish and below the tile edges with a popsicle stick which i passed over in both directions in profile like a level
that is a significant gap and the only piece i had that fell off (held vertically which is not how i intend to use my DF!) was one of the wavy cavern walls (which are pretty heavy) - i only used one magnet on each piece
The big thing is having enough space to lay out pieces to dry - while it didn't happen to me - i can see magnets jumping out of the glue to hang out with their friends - these are strong little magnets!
thanks to those who blazed this trail - this is really making DF much more practical for me to use
Thanks for this. I have a lot of the old stuff I needs to put magnets on.
Post by kitenerd » Wed Oct 10, 2018 1:47 pm
sorry for double pics - my first vertical picture posted horizontally so i just reshot it cause it was terrible anyway
i was just excited that it worked and wanted to let others know how easy it was - i did 50 pieces last night in less than an hour
