Floor peice for joining passage to circular room?
Jenney will answer questions in the Codex Valoria.
You may carry on discussions in the Pre-Kickstarter News and the Kickstarter 5 Discussion Forums.
Re: Floor peice for joining passage to circular room?
Post by jackattack » Thu Jul 06, 2017 11:23 am
If you add standard wall or door pieces between the curved walls (make a + shape with floors, put walls or doors at the ends, then add large curve pieces), passages join right up to the big(ger) round room.
Post by JenneyOC » Tue Jul 04, 2017 7:33 pm
There are large curve half floors within the leverl chamber encounter. there has been talk about adding them else where as well, but nothing confirmed. I have heard not word about 2x2 curved half floors. I see they are sold out on the DF webstore and are awaiting restock so I will ask.
Mitch
Post by Mitch » Mon Jul 03, 2017 10:48 pm
Hiya Jenney,
Is there a plan to add a floor piece so that you can join a passage to a circular room?
Here's the setup:
1. 2x2 wide passage using free standing walls with tabs and 2x2 floor pieces.
2. Circular room using 4 Vaulted Large Curve walls (3 with Large Curve Wall Solid Inserts and one without to form the entrance).
3. The passage joins the circular room where the missing Large Curve Wall Solid Insert would be.
Issue: passage floor ends with a straight edge (2 inch wide) but joins the curved wall so there is like a small C-shaped gap in the floor. Passage walls are OK as they butt right up against the curved wall.
This is sort of like how there was a 2x2 Flagstone Cutout piece in the Tower Transition pack for people who wanted to join a round tower to straight walls:
But to join a passage you'd need something like this (replacing the "pointy end" with a flat end to join to a 2x2 floor tile and making the curve fit the Large Curve Wall shape):
