Wiki
Re: Wiki
Post by GardenDM » Mon Apr 23, 2018 11:34 am
Thanks for the heads up and all the great work maintaining the wiki!
Wiki
Post by Vegomatic » Mon Apr 23, 2018 12:54 am
A few days ago I was notified of a change to the wiki. I saw that they had renamed the site. Normally I wouldn't care one way or the other, but I just found out the renaming broke the link to the site. :shock:
As it has been a while since I did any updates, I went out to make a few minor adjustments this evening and noticed that my bookmark and history links no longer worked. :(
Apparently the update was by a Wikia staff member. They renamed the site from "Dwarven Forge Collector Catalog Wikia" to "Dwarven Forge Collector Catalog Wiki" without setting up forwarding. So if you go to the old URL you will see a note indicating the page was deleted and moved... you can follow the link to the new URL from there.
If you have a bookmark to the wiki the "a" at the end of the URL has been removed... This is the new URL:
http://dwarven-forge-collector-catalog. ... talog_Wiki
The link in my sig block has been updated. 8-)
Just to be clear, this was not complaining that a change was made, this was notifying everyone that the site moved. I don't mind the change (in fact I think it was appropriate), I mind that they did a change like that without setting up automatic forwarding.
That is all. :-)
