Dwarvenite interoperability with master maze?
Nate Finch
Re: Dwarvenite interoperability with master maze?
Post by Nate Finch » Wed May 30, 2018 3:50 pm
Great responses, thank you! Sounds like, for my purposes, yes, they basically work. I'm probably not going to have several feet of different types intermixed.
Post by Oldent » Wed May 30, 2018 2:08 pm
Thwank wrote:
Wed May 30, 2018 1:13 pm
Hey someone gave me this post when I asked the same question, and it was really helpful. GL!
https://www.dwarvenforge.com/forum/view ... =32&t=7592
Thank you. I did not see that when it was posted. It looks like a lot a variation.In practice everything is still compatible :D
Post by pacarat » Wed May 30, 2018 1:27 pm
Sewer walls are significantly higher than the KS1 walls.
Post by Oldent » Wed May 30, 2018 1:22 pm
The best answer is that it is very compatible.
There are some small differences that creep in from time to time but it is not enough to worry about most of the time :!:
Over several feet the differences can show up. It is an easy work around.
Much of the time the difference is hardly noticeable.
No one has ever pointed the difference out during a game.
Post by AnimeSensei » Wed May 30, 2018 1:19 pm
Tough question.
The resin sets are all slightly different due to the way resin works. No two pieces are exactly the same, and even sets like the Woodland set are different than other DF sets, however they strive to be 25mm per square, or 50mm per 2x2 piece. That's slightly under 2 inches. (50.8mm = 2 inches)
The dwarvenite dungeons and caverns are also sculpted to be approximately 25mm per square, though there is some difference between different pieces. Dwarvenite city and castle pieces are in inches instead of mm, so the pieces have a slightly larger footprint and height. Not noticeable in small scale, but if you are doing long lines of city or castle stuff next to long lines of resin or dwarvenite dungeon/caverns stuff it is noticeable.
Floor heights/thickness are all interchangeable and have no issues. Wall heights are the same as the footprints described above, either in mm or in inches, depending on the set.
Welcome to the forums!
102 Resin and 210 Dwarvenite Sets/Packs Owned
Thwank
Post by Thwank » Wed May 30, 2018 1:13 pm
Nate Finch
Post by Nate Finch » Wed May 30, 2018 12:53 pm
I just ordered my first batch of Dwarvenite DF dungeon tiles .... I'm wondering if the resin master maze stuff is the same size? Like if I see a cool resin piece on eBay, would it match up with the dwarvenite tile dimensions (floor thickness, wall height etc)?
Same question for the DF castle stuff - somewhere it said the castle stuff is "true one inch squares"... Is that different than the dwarvenite dungeon tiles? Are the floors the same thickness?
