Inside diameter of pool on 4x4 floor?
Re: Inside diameter of pool on 4x4 floor?
Post by Oldent » Sun Nov 11, 2018 8:31 am
pacarat wrote:
Sat Aug 18, 2018 8:50 am
Planning to do some mods for this piece, and looking for a sanity check.
I'm going to put some removable circular inserts in the pool area, and want to get close enough that they fit well, but don't rub against inside of raised stone rim. Maybe a mm or two of slack.
I have measured the inside diameter at about 74mm.
It looks like the inside edges are uniform so that the diameter is consistent all around, but not 100% on how level the floor is along the outer edge. Anyone tried putting a circular insert in these? Is 74mm accurate?
I used a clay cutter.
I had one that was close. It was probably a cookie cutter.
2 and 28/32 inches
Green Stuff roller http://www.greenstuffworld.com/en/textu ... hulhu.html
Post by pacarat » Sat Aug 18, 2018 8:50 am
