Cavernous Lair
realarete
Cavernous Lair
Post by realarete » Sun Sep 02, 2018 9:29 am
Prepping for our next session, I wanted to share the initial sketch and then possible cave layout - Any feedback welcome! I have Resin cave sets and a couple pcs of dwarvenite to work with. Usually I draw out the caves, then try to construct the map using the DF cavern pcs. In this scenario, the adventurers find an Old Mill (ruined) and delve into the flooded basement level. There is a small underground catacomb area a ways off beneath some outworks buildings, and these two areas are joined by some natural caverns, now a foul lair, and exposed due to some flooding and collapsing ... The cavernous portion follows:
Initial Sketch of the connecting natural caves
Caverns build
View down entrance to Caverns
Transition to tunnel to Catacombs
More twisting caves ...
The back of the Caves with an elevated narrow cavern, and a cramped dark lair area :twisted:
A final shot, entrance into a cave of bones and darkness ....
Re: Cavernous Lair
Post by Arcarius2001 » Sun Sep 02, 2018 10:53 am
I like it!! That elevated portion with the arch from the lake expansion set (or is it rivers, I forget) looks fantastic! Having changing elevation adds to the realism of the environment. The only thing I may suggest is to add a bit of the water pieces, maybe a couple banks and add the free standing wall on the water side. Kind of gets the feeling of being flooded.
I love the old resin cavern line, it still has no equal in my opinion.
realarete
Re: Cavernous Lair
Post by realarete » Sun Sep 02, 2018 10:58 am
Oh the water idea is excellent! Ill work on incorporating that and get a picture added when I do. Thanks for the feedback! Yes the arch is indeed from the Lake expansion.
Re: Cavernous Lair
Post by unclebilly » Sun Sep 02, 2018 11:55 am
Looks awesome and so does your drawing.
realarete
Re: Cavernous Lair
Post by realarete » Sun Sep 02, 2018 12:02 pm
Thanks much! Lots of inspiration on these forums!
fnordfriendly
Re: Cavernous Lair
Post by fnordfriendly » Tue Sep 04, 2018 11:34 am
Awesome build, love the old resin caverns sets. Did you draw the map first, or after you set it up?
realarete
Re: Cavernous Lair
Post by realarete » Tue Sep 04, 2018 9:10 pm
I sketched first, then tried my best to put the resin to it ... I'll post the Mill basement cutaway drawing and build this weekend I hope.
realarete
Re: Cavernous Lair
Post by realarete » Fri Sep 14, 2018 5:03 pm
Did a test build of the basement of the mill - A stairway winds down into a lowering cave, partially flooded, and leads into a formed hall ... beyond the hall is a narrow, crumbling cavern corridor, roots and water threaten to crash down from the flooded yards above ... I have limited resin sets, and a few odd ball pcs of dwarvenite :)
Ive left the one side open deliberately to give a bit of access to move minis etc...
Heres the sketch of the cross-section:
View long direction:
View of the cavern-like passage at end ( which leads into the Cavern Lair in the other post)
View of the Stairs section ... flooded up to the height of the corridor
Another view of stairs section :
A bit of a scramble up rough terrain and under water :shock:
Another view of the stairs:
The passage narrows, it is here in the sketch that after the first adventurer makes their way through, the rocks collapse! Trapping the one adventurer on the side that leads to the Lair, and the others in a corridor that is filling with swamp water! Several athletics/end checks need to be made to gain the stairs and back up to the first floor of the mill ... But the water has forced the nests of rats up there as well .... dire straights for both groups of adventurers!
Final shot:
The main group of the party must survive the water trap and drowning, deal with the rats, and make their way to the out-buildings and the Catacomb beneath, to met up with the trapped member who (if they get too bold) is stuck by themselves in the cavern area with an old Troll ...
Will post the Catacomb section ( the final section , I promise :roll: ) once I get a test build of it set up.
Re: Cavernous Lair
Post by kitenerd » Sun Sep 16, 2018 3:08 am
Super clever little encounter designed in a compact footprint - i love it!
Of all the things you can throw at players, there is nothing as terrifying as slowly rising water!
Re: Cavernous Lair
Post by Arcarius2001 » Sun Sep 16, 2018 10:04 am
That looks great! I really like the look of the dungeon stairs and mountain pieces. It looks like something out of Indiana Jones, old and abandoned leading somewhere dangerous. That you sketch it first amazes me.
Return to “Module / Map Ideas”
