Some Painted Minis
Re: Some Painted Minis
Post by Oldent » Fri Jan 18, 2019 6:41 pm
lostpict wrote:
Fri Jan 18, 2019 6:24 pm
Thanks for the info a photos if the Mb antic library parts. I think I will pass and hope DF makes something similar scales a bit smaller.
I hope they make something scale better too!
Post by lostpict » Fri Jan 18, 2019 6:24 pm
Thanks for the info and photos of the Mantic library parts. I think I will pass and hope DF makes something similar scales in a bit smaller.
Post by Oldent » Fri Jan 18, 2019 5:55 pm
I turned up a floor section. I will make a LED work face too.
Post by Oldent » Fri Jan 18, 2019 2:28 pm
I am also working with the mine set.
I will fill the light leak before I paint.
tea lights will vary by brand
You may need to modify the hole for the switch.
You can use card or Plastic sheet if you do not already have the correct drill bits. With the MDFB use the large bit first then drill the smaller whole. Cut out the space for the switch with a chisel.
If you have to use a spade bit, drill all the way through the base. Use card instead of trying to drill the small whole. Something like cereal package will do.
DM Mark has a u tube video on modifying DF tiles you may want to watch. I prefer to make new bases.
I will make more WIP photos as I paint.
Post by Oldent » Fri Jan 18, 2019 10:25 am
zenako wrote:
Fri Jan 18, 2019 9:41 am
@Oldent, I think I have more interest in the fruit cart in the next picture in that blog. My settings tend to be far less refined where the players tend to roam.
I am doing a little Gothic so I wanted a big library.
I want the fruit stand too
Post by zenako » Fri Jan 18, 2019 9:41 am
Post by William » Thu Jan 17, 2019 5:51 pm
They look like 1/8" to 3/16" too tall for the walls.
Bummer, guess I'll pass. Oh well. :|
Thanks for doing this post, I've been wondering about them since the KS.
Post by Oldent » Thu Jan 17, 2019 4:40 pm
zenako wrote:
Thu Jan 17, 2019 4:07 pm
Checked out the library parts. They are slightly taller than a CBS wall or Corner post, so stacking multiple floors would be an issue, but for a single floor location, not much of an issue, as you can see in the pictures above. A full bookcase and half bookcase nicely sit between two corner posts, but it is snug. Two full bookcases will cover the edge of a floor tile. The bookcases do stack fairly well so having a double height wall of wisdom is very possible, and that makes the ladders more appropriate. I suppose if someone was using the double height corner posts that would be a way to contain a double height wall of wisdom. Without any way to stick them together however, i could see that double stack taking a tumble without much trouble from any sort of table bump.
https://manticblog.com/2019/01/05/12-da ... raincrate/
Gothic Estate
I want to include the Grand Piano. The music room will have to be separate from the library ;)
Post by zenako » Thu Jan 17, 2019 4:07 pm
Post by Oldent » Thu Jan 17, 2019 11:42 am
It looks like it might work better than I thought from the Photos with the CB walls. :D
I am going to use the bookshelf with some large open tiles I am going to make for Mansions of Madness.
